Configure an IPv6 redistribute entry to announce IPv6 routes of a certain source protocol type into the BGP domain, for example, static, OSPF, IS-IS, RIPng, or direct routes. Use a route policy to control the redistribution of routes.
When a route map with attributes set to origin and local-pref is applied to the BGP redistribute command, the attributes are not applied to the redistributed routes.
If required, a route policy exists.
Specify a route policy to govern redistribution by using the following command:
Switch:1>enable Switch:1#config terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#router bgp Switch:1(router-bgp)#redistribute ipv6–direct route-map policy2
The following table defines parameters for the redistribute <ipv6-direct|ipv6-isis|ipv6-static|ospfv3|ripng> command.
Variable |
Value |
enable |
Enables the BGP route redistribution instance. The default value is none. |
metric <0–65535> |
Configures the metric to apply to redistributed routes. The default value is 0. |
route-map <WORD 0-64> |
Configures the route policy to apply to redistributed routes. The default value is none. |
Job Aid
Use the data in the following table to know how route policies are used for BGP from IPv6 perspective.
REDISTRIBUTE |
ACCEPT |
ANNOUNCE |
IPv6 Direct |
IPv6 Static |
OSPFv3 |
IPv6 IS-IS |
RIPng |
BGP |
BGP |
MATCH |
as-path |
Yes |
Yes |
community |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
community-exact |
Yes |
Yes |
extcommunity |
Yes |
Yes |
interface |
local-preference |
metric |
Yes |
Yes |
network |
Yes |
Yes |
next-hop |
Yes |
Yes |
protocol |
route-source |
Yes |
route-type |
Yes |
Yes |
tag |
vrf |
vrfids |
SET |
as-path |
Yes |
Yes |
as-path-mode |
Yes |
Yes |
automatic-tag |
community |
Yes |
Yes |
community-mode |
Yes |
Yes |
injectlist |
Yes |
Yes |
Yes |
Yes |
Yes |
ip-preference |
local-preference |
Yes |
Yes |
mask |
metric |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
metric-type |
metric-type-internal |
next-hop |
Yes |
Yes |
nssa-pbit |
origin |
Yes |
origin-egp-as |
tag |
weight |
Yes |
